File Geodatabase API Blog
92
201.3K
POST | Currently we still use FileGDBAPI.dll in version 1.5.1 and it works fine. We wanted to upgrade to the latest version ... by MarcinWieczorek New Contributor 0 0 | 0 | 0 | 337 | |
POST | Howdy folks. I'm not using the FGDB API at all. But I think is the best community/forum to ask because it's a questio... by AZendel Frequent Contributor 0 1 | 0 | 1 | 567 | |
POST | The File Geodatabase API 1.5.3 released in June 2024 is now available for download from the Esri/file-geodatabase-api... by Diana_Muresan ![]() 1 0 | 1 | 0 | 851 | |
POST | Hello.I'm using FileGDB API for .NET 1.5.3I cannot get the field definitions of a feature class in an FGDB.Here's the... by AlexanderGleyzer2 New Contributor 0 0 | 0 | 0 | 639 | |
POST | Hi,I'm getting a General Function Failure when I try to use GetString in a row.I can get the field information and ty... by PeterRollier New Contributor 0 0 | 0 | 0 | 650 | |
POST | Is there a way to create a standalone table in a FGDB using the file geodatabase API?If yes, does the table get autom... by Bud Esteemed Contributor 0 1 | 0 | 1 | 1445 | |
POST | Does anybody have a sample in C# that create a GDB, create a feature class in it and add a point to this feature clas... by mody_buchbinder Frequent Contributor 0 3 | 0 | 3 | 2322 | |
POST | Hai, i want to read blobs field data size from my filegdb by fileGDBAPI with C++, But i always get NULL Binary data... by LiuYingying New Contributor 0 0 | 0 | 0 | 1060 | |
POST | Hi there,I want to import a FGDB into a Xamarin forms application, but I can't find an easy way to do it. I simply wa... by SaghiKhani New Contributor 0 0 | 0 | 0 | 1135 | |
POST | i have succesfuly queried for a single envelope and returned the parcel data in geojson.https://services1.arcgis.com/... by Tman New Contributor 0 0 | 0 | 0 | 1082 | |
POST | We have some customers and partners still relying on the File Geodatabase API. Currently, they try to migrate or at l... by Jan-Tschada ![]() 2 3 | 2 | 3 | 1766 | |
POST | Regarding the docs: SQL for reporting and analysis on file geodatabasesWhat parts of ArcGIS does the syntax in that p... by Bud Esteemed Contributor 0 1 | 0 | 1 | 1809 | |
POST | Is there documentation that outlines what functionality was released at each FGDB version, and when?Fake examples:Ver... by Bud Esteemed Contributor 0 0 | 0 | 0 | 1136 | |
POST | 0 | 1 | 1381 | ||
POST | I have configured the FileGDB API with Visual Studio 2019, and I can read the data in the geodatabase. But I want to ... by HuYuChen New Contributor 0 0 | 0 | 0 | 1540 |
