Map Layers Widget Custom 1.17
2256
04-02-2025 02:28 PM
Brian_McLeer
MVP Regular Contributor
From this community post:
Expand Grouped Layers by Default
I have modified the out of the box widget for 1.17:
Highest level group layer expanded by default
Change the map search to a filter icon and say Filter Layers with filter text open by default
Tick boxes or eyes collapse or expand layers automatically
Supports regular widget options
Changelog:
2/6/26: 1.19 version posted
Brian_McLeer
Tested widget in DE 1.18 and works as is. Note that the FGDB, KML, and Shapefile Export options are not working for me in this widget, but I experience the same issue in the out of the box widget.
https://community.esri.com/t5/arcgis-experience-builder-questions/experience-builder-developer-editi...
Brian_McLeer
Developer Edition 1.19 was released today (11/13). I tested the widget and everything looks to functioning the same as it was at DE 1.18.
EricLacoursierePQ
Hi @Brian_McLeer ,
Enable layer batch options. triggers the filter layer option on my end on 1.19.
It would be nice to be able to batch enable / disable layers if you have time to have a look.
Eric
Brian_McLeer
Hi @EricLacoursierePQ, I just sent you a direct message with an updated ZIP file. I tested on my end and the issue looks to be resolved. If your testing works out and the issue is resolved, I will update this post.
