Code sharing
994
05-13-2024 02:56 AM
majae
Hello! I am trying to use code sharing in my project (https://developers.arcgis.com/experience-builder/guide/share-code-between-widgets/#shared-entry). I am using the shared entry method. My folder structure is as follows,
widgets/
  shared-code/
    entry1.ts
    lib/
      entry1/
        myCustomButton.tsx
        translations/
          default.ts
          sv.js
I am able to import 'myCustomButton' using "import { sampleFunction } from 'widgets/shared-code/entry1'" as instructed in the guide.
But, i have two problems.
1. The translation file 'sv.js' never runs.
2. The entry file 'entry1.ts' is not generated on build. 
Does anyone know how i solve these problems?
Thanks in advance!
MatejKutik
Hi, I’m experiencing the same problem. Have you solved it?
