Filter Data on Map and then Export Filtered Data to CSV
4329
9
04-05-2024 01:24 PM
RezaTehranifar2
I have an application that has filter widgets that interacts with the map on the page. The client would now like to be able to export the data to csv. I am a little tight in space I dont want nor need to see the data in a table. Has someone created a widget that does this? I dont think I found one yet but I will continue looking while I wait for responses.
Is there a hack? Ideally I just want a button that says export to csv.
JeffreyThompson2
MVP Frequent Contributor
function customExportCSV() {
    let query = featureLayer.createQuery()
    query.where = '1=1'
    let csv = ''
    let headers = ''
    featureLayer.queryFeatures(query).then((featureSet) => {
        headers = Object.keys(featureSet.features[0].attributes).join(',')
        for (let i = 0; i < featureSet.features.length; i++) {
            const data = Object.values(featureSet.features[i].attributes).join(',')
            csv += data + '\n'
        csv = headers + '\n' + csv
        downloadCSV(csv)
function downloadCSV(csv) {
    const csvFile = new Blob([csv], { type: 'text/csv' });
    const downloadLink = document.createElement("a");
    downloadLink.download = 'search_results.csv';
    downloadLink.href = window.URL.createObjectURL(csvFile);
    downloadLink.style.display = "none";
    document.body.appendChild(downloadLink);
    downloadLink.click();
Here's my function for downloading a csv from a FeatureLayer.
GIS Developer
City of Arlington, Texas
JeffreyThompson2
    query.where = '1=1'
    let csv = ''
    let headers = ''
            csv += data + '\n'
        downloadCSV(csv)
GIS Developer
RezaTehranifar2
This is great. Thanks!
This is assuming there is only one layer in the map. Correct? My map has multiple layers.
JeffreyThompson2
It will download data from whatever feature layer is assigned to the variable featureLayer. To make it more flexible, make featureLayer a parameter of the customExportCSV function, then create another function that finds a feature layer from a user input and calls customExportCSV(featureLayer).
GIS Developer
RezaTehranifar2
Thanks. I am so so on JS, so I may hardcoded as you have it above at first, but I will work on the additional code to make it for flexible. Thank you for the outline of that part.
ShahranNewaz
Hey, so I'm currently working on this, and I just need a little help as I'm not too familiar with esri. In regards to the featureLayer variable, how are you pulling the layer from the map and assigning it to the variable?
JeffreyThompson2
If you added the layer to the map, you can use the variable you created at assignment.
If you need to get a layer out of the map, this line of code should work, assuming you have captured the mapView created by Experience Builder to the jimuMapView variable and found the correct id of the layer to plug into the string.
const featureLayer = jimuMapView.view.map.findLayerById('layerId')
GIS Developer
ShahranNewaz
This is the code I have. I'm saving the mapView state into jimuMapView variable in line 12. But, Im running into an "Property 'createQuery/queryFeatures()' does not exist on type 'Layer'." on lines 23 and 28. Can you take a look thx
import React from 'react';
import { AllWidgetProps } from 'jimu-core';
import Setting from '../setting/setting';
import { UseDataSource } from 'jimu-core'
import { JimuMapViewComponent, type JimuMapView } from 'jimu-arcgis'
const { useState } = React
const Widget = (props: AllWidgetProps<unknown>) => {
  const [jimuMapView, setJimuMapView] = useState<JimuMapView>()
  const buttonStyle = {
    fontSize: '',
    padding: '10px 20px',
    borderRadius: '5px',
    const featureLayer = jimuMapView.view.map.findLayerById('layerId');
    let query = featureLayer.createQuery();
    query.where = '1=1'
    let csv = ''
    let headers = ''
        csv += data + '\n'
      downloadCSV(csv)
  return (
    <div className="widget-demo jimu-widget m-2">
      <link rel="stylesheet" href="https://cdnjs.cloudflare.com/ajax/libs/font-awesome/4.7.0/css/font-awesome.min.css"></link>
      <div className='inside-card'>
        <header>{Setting.value}</header>
        <Button style={buttonStyle} onClick={customExportCSV}>Export Data</Button>
      </div>
    </div>
export default Widget;
JeffreyThompson2
https://community.esri.com/t5/experience-builder-tips-and-tricks/boilerplate-for-a-map-related-custo...
You aren't actually capturing the jimuMapView with your code. The easiest way to fix this would be to start over with this boilerplate code and add the csv function to it.
GIS Developer
MK13
@JeffreyThompson2 after applying the where clause and running queryFeatures, how do you get the mapview to update and show the filtered layer?
