Advanced Draw Widget Improvements: Import, Export, Save Drawings, Tool Tips, Snapping, Measurements
8603
63
05-28-2025 07:15 AM
Brian_McLeer
MVP Regular Contributor
33 63 8,603
Advanced Draw Widget Capabilities
This widget release builds upon contributions by @JeffreyThompson2 , @RobertScheitlin__GISP , and @AdrienHoff11 , incorporating all functions from prior iterations while adding significant new capabilities across two main areas, the Draw tab and My Drawings tab.
This release builds upon these prior releases:
Additional Draw Widget Improvements (4/10/2025)
Re-designed Draw widget (11/21/2023)
Draw Widget EB 1.7.0 (1/28/2022)
Draw Tab Enhancements
Measurement System
A comprehensive measurement system providing professional-grade accuracy and real-time calculations:
  • Real-time calculations – Automatic area, perimeter, length, and coordinate calculations that update as graphics are modified.
  • Multiple unit support – Distance units (kilometers, miles, meters, nautical miles, feet, yards) and area units (square kilometers, square miles, acres, hectares, square meters, square feet, square yards).
  • Custom unit definitions – User-defined distance and area units with conversion factors.
  • Coordinate display – XY coordinates, Lat/Long coordinates, and spatial reference WKID information.
  • Advanced measurements – Circle radius calculation and individual line segment measurements for complex shapes.
  • Intelligent processing – Geodetic vs planar calculations based on spatial reference, with automatic label management.
  • Configurable controls – Individual toggles for length, area, perimeter, radius, and segment displays.
Tooltips
  • Real-time measurements – Live tooltips with length, area, perimeter, radius, and coordinate updates as drawing progresses.
  • Configurable units & precision – Custom unit support and decimal rounding controls.
  • Smart placement & display – Automatic positioning and styling for clear visibility.
  • Interactive integration – Adapts to active drawing tools and user interactions like resizing and editing.
  • Coordinate display – Optional X/Y, Lat/Long, and WKID information for points.
  • Segment labels – Supports segment-specific tooltips for polylines.
  • Error handling – Fallbacks for unsupported geometries and projection warnings.
  • Performance optimized – Efficient rendering with minimal impact on performance.
Snapping
Advanced snapping functionality for precise drawing alignment:
  • Multi-layer snapping – Detects all visible snappable layers with recursive layer hierarchy search.
  • Comprehensive layer support – Includes feature layers, graphics layers, CSV, GeoJSON, WFS, and sublayers.
  • Smart functionality – 15-pixel snap tolerance, self-snapping, and temporary disable via Ctrl/Cmd key.
  • Automatic optimization – Layer loading and efficient snapping management with user feedback.
Drawing Tool Improvements
  • Reorganized layout – Two-row button arrangement with logical grouping (Point/Line/Freehand Line/Text top row; Rectangle/Polygon/Freehand Polygon/Circle bottom row).
  • Enhanced feedback – Clear indicators for "Drawing Mode," "Edit Mode," and "No Drawings Yet."
  • Dual-tab interface – Seamless sync between "Draw" and "My Drawings" tabs.
Text Tool Enhancements
  • Expanded font library – 11 font families including Alegreya, Josefin Slab, Merriweather, Montserrat, Noto Sans/Serif, Open Sans, Playfair Display.
  • Advanced styling – Real-time preview, enhanced rotation, multi-line support.
  • Sophisticated effects – Text outline/halo with size and opacity controls, font family selector.
Layer Management
  • Dynamic controls – Toggle visibility of the drawing layer in the map layer list.
  • Customization – Custom layer naming with collapsible settings panel.
  • Configuration options – Toggle between show/hide modes for the graphics layer.
My Drawings Tab
Storage & Data Management
  • Local storage integration – Saves drawings in browser with user consent management.
  • Session continuity – Remembers drawings across sessions on the same device/browser.
  • Load options – Detects existing drawings with options to load or start fresh.
  • Import/Export – JSON file-based backup and restore.
Drawing Organization
  • Selection system – Individual and bulk selection with checkboxes.
  • Sorting options – Sort drawings by name, type, or creation date.
  • Search and filter – Easy navigation through large drawing collections.
Editing Capabilities
  • Name editing – Inline renaming of drawings.
  • Symbol modification – Edit drawing symbols and styles.
  • Text styling – Full text formatting including alignment, color, font, and decorations.
  • Copy/duplicate – Clone drawings for reuse.
User Experience Features
  • Confirmation dialogs – For single and bulk deletions.
  • Visual feedback – Selection highlighting and map interaction.
  • Accessible design – Tooltips, keyboard navigation, screen reader compatibility.
  • Responsive layout – Mobile-friendly with touch support.
Advanced Operations
  • Undo/Redo system – Full action history management.
  • Bulk operations – Multi-select delete, export, and modification.
  • Error handling – Robust error feedback and handling.
  • Performance optimization – Efficient rendering and memory management.
Features Not Currently Supported By ESRI Draw/Measure Widgets
  • XY Point Locations
  • Make Your Own Units of Measure
  • Measure Line Segments and Radius
  • Snapping Is An Easy-to-find User Option
  • Users Can Control The Number Of Decimal Places in Measurement
  • Users May Add/Remove Measurements After Drawing
  • Measurement Text Style Is Controllable
  • Freehand Polylines and Polygons
  • Change Drawing Styles and Text Options After Drawing
  • Point Symbol Rotation
  • Accurate Text Previews
  • User Options For Choosing the Name of the Drawing Layer and If It Displays in Map Layer List
  • Save Drawings To Local Storage and Retrieve Them in a Future Session
  • Import/Export Drawings to File
  • List of Drawings For Easy Management
Changelog
10/27/2025:
Bug fix: When going from Draw to My Drawings with a tool selected, the tool will stay active so you can still draw graphics when on the My Drawings Tab. The ZIP has been updated to resolve this bug.
10/15/2025: Version 2 released
Buffer
  • Add buffers to drawings including points, lines, polygons, and circles.
  • Configure buffer distance, unit, and opacity interactively.
  • Buffers update automatically when the parent drawing is reshaped or moved.
  • Buffers can be removed individually or cleared all at once.
  • Buffers are included in import and export operations.
Line Arrows
  • Add arrowheads to line drawings to indicate direction.
  • Arrowheads can be toggled on or off while drawing or after creation.
  • Works with both straight and freehand line tools.
  • Arrow styling integrates with existing line symbol settings.
Import/Export (GeoJSON)
  • Drawings can be imported from or exported as valid GeoJSON files.
  • Import GeoJSON created from other GIS tools or previous sessions.
  • Export GeoJSON for use in other applications, including ArcGIS Online and ArcGIS Pro. Note: For KML/KMZ, a third party or additional ArcGIS Pro geoprocessing operation will be needed (https://mygeodata.cloud/converter/, https://mapshaper.org, or others may be a viable option).
  • Maintains geometry and attributes for consistent round-tripping.
  • When importing into ArcGIS Pro single drawings in a GeoJSON file, use the JSON to Features geoprocessing tool and ensure the valid geometry is selected in the Geometry Type drop-down (text not supported).
  • When importing into ArcGIS Pro with multiple drawings in a GeoJSON file, use the Batch Import Data geoprocessing tool. This supports importing multiple geometry types from a single GeoJSON file (text not supported).
  • Legacy JSON files from previous versions of the widget can still be imported for compatibility.
Measurement Label Editing
  • Measurement labels can be repositioned by dragging.
  • Text properties such as size, color, font, halo, bold, italic, and underline can be adjusted.
  • Updates are applied instantly to labels on the map.
  • Supports editing labels for points, lines, polygons, and circles.
  • Improves map readability and customization without redrawing geometries.
Measurement Label Improvements – Special thanks to @MattiasEkström  for assistance on this portion
  • Segment labels for lines and polygons can now be rotated to match the orientation of the underlying segment.
  • Users can toggle between oriented labels (aligned with the line or polygon segment) and straight horizontal labels.
  • Rotated labels dynamically follow the shape of the line as it is edited.
  • This improves readability on curved or angled segments and provides more control over how measurements are displayed.
Delete All (My Drawings)
  • A new Delete All button has been added to the My Drawings panel.
  • Allows users to quickly remove all drawings at once.
  • Includes a confirmation step to prevent accidental deletion.
UI Updates
Known Issues
  • Circles Aren't Real - Circles generated by this Widget are actually 60-sided polygons and there is no good way to tell how a drawing was created after the fact. As far as this Widget is concerned, any polygon with exactly 60-sides is a circle. If you create your own polygon with exactly 60-sides or distort a circle so that it is no longer circular, it will be treated as if it is a circle and calculate a radius.
  • Freehand Line Segments - Technically, freehand line segments work fine, but they generate too many labels to be useful. For reasons similar to the circle problem above, there wasn't a good way of disabling the line segment option for freehand drawings, but it's a bad idea to use them.
  • Make Your Own Units Will Clear Your Default Unit Selection - After creating or editing your units in the Builder, your selected default unit will be cleared. You may need to select a unit of measure other than your desired choice, save Experience Builder and then switch back to your desired choice and save again. This issue is semi-intentional for the following reasons:
    • I could not get Experience Builder to recognize changes to the unit list and unlock the save button.
    • The default unit is passed as the index of an array, so creating or deleting units could result in the incorrect unit being selected or an out-of-range error.
  • Text Color Problems -
    • When first selecting a Background Color, you must first change to one of the Standard Colors. After selecting a Standard Color, all of the options will work.JeffreyThompson2_1-1748439750037.png
    • In all of the Text Color Pickers, dragging the sliders will result in many duplicated copies of the text being edited. Clicking on the sliders will not cause a duplication issue.JeffreyThompson2_2-1748439913820.png
63 Comments
Brian_McLeer
Thank you for all of the snippets @GeoguichetGeoguichet, I will review these and see if I can replicate behavior and see if we can get an update on our end in the near future.
adamsimple
@Brian_McLeer
Hello! It looks like there is a compatibility issue with ExB 1.19. The widget is attempting to access a legacy theme property. The issue is in style.css, this line:
const root = theme.surfaces[1].bg;
KevinHitchcock
For polylines I'm getting the "Total:" label even when I have Length labels turned off if the Line Segment labels are turned on. Is there a way to stop that behavior? I downloaded the .zip today from this page. Using ExB Dev 1.19.
Brian_McLeer
Thank you @adamsimple and @KevinHitchcock for reporting both of these issues. We will look at both of these and try to resolve them soon.
JasonCityOfTacoma
Hi, @Brian_McLeer
Great work on this and thanks for sharing.
Is there a github repo for the project that I could clone or fork? I'd be happy to help contribute in any way that I can, but I didn't see one when I did a basic search. I'd love to say up to date with future changes and help out with feature enhancements.
Cheers,
Jason Schotman
jschotman@tacoma.gov
Brian_McLeer
Hello @JasonCityOfTacoma, currently we don't have a GitHub repo. I have been wanting to get a repo for several custom widgets onto GitHub. We may be having an update in the near future and posting on this blog. After that, I will probably look into a GitHub repo to get downloads onto as well.
Thank you,
Brian
HeatherWidlund
Forgive the novice question, but is there a way to add a drawing using the geometry of a selected feature? I poked around a bit but didn't see other widgets addressing this.
Brian_McLeer
Hello @HeatherWidlund, don't think it is a novice question, please feel free to reach out on this blog for any questions or ideas. Currently no, there is not a way to use the geometry of a selected feature to copy and paste into my drawings. The closest way would be to enable snapping on the layer being selected and then draw over your selected feature to snap to the vertices of the line or polygon. The only widget that may have this capability is the out of the box edit widget, but I don't think copy and paste is available yet.
HeatherWidlund
Thanks, @Brian_McLeer! I'm very new to ExB so I'm never sure what I'm missing from OOTB or custom capabilities. This is possible in the custom, configurable Vertigis Studio offering but I was wondering if it's somewhere in ExB.
Marshal
@HeatherWidlund
That is pretty much exactly what my "Show on Map Layers" widget does.
1)  Use any method to select a feature (Select widget, Table widget, etc.)
2)  Use the "Show on Map" data action to create a temporary layer of the selection
3)  Download the layer as json and then import that same json into draw-advanced widget
https://community.esri.com/t5/experience-builder-custom-widgets/show-on-map-layers-widget/tac-p/1637...
In the builder configuration, make sure you toggle Draw-Advanced Compatible JSON.
Hope it helps!
HeatherWidlund
Thank you, @Marshal, your widget looks great! However, from the user perspective, it's not as simple as using an actions menu to "Add to drawing layer", or am I missing something?
wrennmusic
Occasional Explorer
This widget is a great alternative to purchasing creator licenses for my department - thank you for making this available to other users. 🙂
However, the edit vertices option seems to be buggy. Sometimes it works, sometimes it doesn't. There doesn't seem to be any obvious reason why it works when it does, or what causes it to stop working. Any guidance would be greatly appreciated.
Additionally, my department heavily relies on google earth. It would be great if the tool had the option to export drawings to KMZ as well, even though they have been shown how to import the geojson to google earth. It would be helpful if the tool also had the option to import KMZs as well.
Thank you!
Brian_McLeer
Thank you @wrennmusic.  If you subscribe to this blog some updates may be happening in the near future to fix the vertices issue and KMZ as an option.
About the Author
GIS Administrator/Developer at City of Grand Junction, CO.
