{"error":"no handler found for uri [/metadata/item/_search?from=0&size=10&sort=title.sort%3Aasc] and method [GET]"}
13811
06-08-2022 07:27 AM
YinShi
Hello everyone,
When setting up Geoportal 2.6.5 with ElasticSearch 8.1.3 on a Windows 10 VM, I followed the installation steps outlined here:
https://github.com/Esri/geoportal-server-catalog/wiki/Installing-Geoportal-Server-2.6.5
When I tried to start Geoportal in a browser, I got the following error
The exact error message was
I then disabled security for Elastic Search which was on the same VM, as well added Simple Security Manager for Geoportal. I still had the same error.
I checked ES log and there was nothing logged. The latest entries in Geoportal log indicated communcation was good between GeoPortal and ES
2022-06-08 09:47:09,162 DEBUG [com.esri.geoportal.lib.elastic.ElasticContextHttp] - Checking index: metadata
2022-06-08 09:47:09,472 INFO [com.esri.geoportal.lib.elastic.ElasticContextHttp] - Elasticsearch version: 8.1.3
Would anyone has any  suggestions for me to troubleshoot this issue?
yin
YinShi
Thanks for the API link Marten. It turns out that GeoPortal 2.6.5 would not work with Elastic Search 8.1.3 even when I disabled security in ES. I uninstalled 8.1.3 and reinstalled 7.9.3 ES. And the error I mentioned earlier was not there anymore.
Marten
hi. The error message indicates that there is no handler for the GET request you submitted. when using this particular API, you will need to use HTTP POST.
you can also use this API: /metadata/search, which supports both HTTP GET and POST.
The API you used is provided as a convenience and it is a direct proxy to the elasticsearch API. The API I recommend allows for the same searches (including elasticsearch query syntax).
To test this and other Geoportal Server API, please check out:
https://gpt.geocloud.com/geoportal_api/#/rest/searchUsingGet
YinShi
