Esri Geoportal Server Questions
Other Boards in This Place
Latest Activity
Sort/Filter :
POST
It is my pleasure to announce that we have released Geoportal Server 2.7.2. To be more specific, Harvester 2.7.2 and ...
Marten
by Marten Frequent Contributor
in Esri Geoportal Server Questions Last Updated 11-22-2024
0 0
POST
Hi Team,Geoportal Server has the capability to harvest data using a UNC path. However, we encountered an issue we har...
Kristofer
by Kristofer Regular Contributor
in Esri Geoportal Server Questions Last Updated 10-14-2024
0 2
POST
Hi @MartenHogeweg, @Marten,I am trying to integrate our fresh Geoportal deployment with our 10.9.1 ArcGIS Portal for ...
Marc_Graham
by Marc_Graham Frequent Contributor
in Esri Geoportal Server Questions Last Updated 03-28-2025
0 2
POST
After harvesting SDE metadata to Geoportal, I noticed topic categories were harvested to keywords_s field, i.e. the n...
YinShi
by YinShi Regular Contributor
in Esri Geoportal Server Questions Last Updated 09-11-2024
0 2
POST
Hi, how could I send a search parameter from another html page?I have GeoPortal running at http://localhost:8080/geop...
LuisFabres
by LuisFabres New Contributor
in Esri Geoportal Server Questions Last Updated 08-07-2024
0 1
POST
When clicking on the xml hyperlink of an item in Geoportal 2.6.5. The xml hyperlink removes all \r\n embedded in the ...
YinShi
in Esri Geoportal Server Questions Last Updated 06-25-2024
0 1
POST
Hello, I am trying to add a field to a published feature within my organization's server. I am allowed to do a join a...
CambriaEwart
by CambriaEwart Emerging Contributor
in Esri Geoportal Server Questions Last Updated 04-19-2024
0 3
POST
This release marks a whopping 20 years since the first release of the standards-compliant, open-source metadata appli...
Marten
in Esri Geoportal Server Questions Last Updated 12-21-2023
4 0
POST
Bonjour,Je souhaite faire une migration des services (publiés sur un ArcGIS Server 10.9)  vers un ArcGIS Server 11.1....
sigssarcgis
by sigssarcgis New Contributor
0 1
POST
hello everyonewe have a problem about ArcGIS server 10.9, so the deal is: our server works fine with port 6080 when w...
Vakhtang_Zubiashvili
by Vakhtang_Zubiashvili Frequent Contributor
in Esri Geoportal Server Questions Last Updated 12-11-2024
0 5
1227
POST
We have geoportal (version 2.6.5) and harvester (version 2.6.5) running in apache server. For the project purpose we ...
ArunPremachandran
by ArunPremachandran Occasional Contributor
in Esri Geoportal Server Questions Last Updated 09-20-2022
0 3
POST
I am testing importing metadata from UNC location. I tried both UNC path name and mapped drive name. Neither worked. ...
YinShi
in Esri Geoportal Server Questions Last Updated 09-08-2022
0 6
1406
POST
Hi ESRI community,I'm trying to locally host the Geoportal 2.6.5 as per the instructions given in the official github...
ArunPremachandran
in Esri Geoportal Server Questions Last Updated 09-18-2022
0 7
2317
POST
I set up a simple UNC path broker on my local C drive. When I imported the metadata (in xml) from c:\temp\TestUNCMeta...
YinShi
in Esri Geoportal Server Questions Last Updated 08-24-2022
0 2
POST
Hi ESRI community,I'm facing an error while saving the custom metatdata created by me. I have posted the error screen...
ArunPremachandran
in Esri Geoportal Server Questions Last Updated 09-22-2022
0 4
77 Subscribers
Top Collaborators
