NetworkAnalyst.LocalRouteTask Exception "Cannot solve."
2358
04-20-2016 07:47 AM
LauraMartinez
I need some help, please
We are currently conducting a traceroute using a network dataset from a .net WPF application (.net sdk esri 10.2.5) and in some cases there is an exception that prevents generating the route. The validation was performed from the ArcMap and the route was generated correctly.
The parameters to generate the route are as follows:
  var routeParams2 = await routeLocalTask.GetDefaultParametersAsync();
                    routeParams2.ReturnDirections = true;
                    routeParams2.DirectionsLengthUnit = LinearUnits.Miles;
                    routeParams2.UseHierarchy = true;
                    routeParams2.ReturnRoutes = true;
                    routeParams2.ReturnPolylineBarriers = true;
                    routeParams2.PreserveFirstStop = true;
                    routeParams2.PreserveLastStop = true;
                    routeParams2.FindBestSequence = true;
                    routeParams2.ImpedanceAttributeName = ListParameters.Find(X => X.ParameterId == "MAP_ROUIM" && X.Application == 1).Value;
                    var stopGraphics2 = new List<Graphic>();
                    stopGraphics2.Add(from);
                    stopGraphics2.Add(to);
                    routeParams2.SetStops(stopGraphics2);
                    routeParams2.OutSpatialReference = SpatialReference.Create(102100);
                    routeParams2.IgnoreInvalidLocations = true;
routeResultLocal = await routeLocalTask.SolveAsync(routeParams2);
Exception :
   at Esri.ArcGISRuntime.Tasks.NetworkAnalyst.LocalRouteTask.SolveMultipleRoutes(RouteParameters settings, Dictionary`2 groupsStopsByRouteName, CancellationToken cancellationToken)
   at Esri.ArcGISRuntime.Tasks.NetworkAnalyst.LocalRouteTask.<>c__DisplayClass7.<SolveAsyncInternal>b__6()
   at System.Threading.Tasks.Task`1.InnerInvoke()
   at System.Threading.Tasks.Task.Execute()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult()
   at Esri.ArcGISRuntime.Tasks.NetworkAnalyst.LocalRouteTask.<SolveAsyncInternal>d__9.MoveNext()
   at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()
   at CADPresentationWPF.EsriMapNet.<AddRoutingToMap>d__476.MoveNext() in e:\Proyecto\RoutingPanel.cs:line 698
But if I chage the value in this field "ReturnDirections" to false, I will get the geometry but I don't get the driving instructions
routeParams2.ReturnDirections = false;
I will really appreciate if anyone can help me with this issue.
MarcoRivera
The problem is solved by checking the vertices, eliminating some unnecessary ones, and rebuilding the network dataset
Resoved by Marco Rivera
