Converting VB Script for Labelling to Arcade
6796
14
07-09-2019 11:57 AM
WilliamDelmar
I have the following VB Script expression for labeling hatches. It worked just fine in ArcMap. As I am now using ArcGIS Pro, I would like some help converting it to Arcade.
Function FindLabel ( esri__measure )
segLen = esri__measure
if  right(int((segLen *3.2808399)),2) = 0 then
  lblStation= int((segLen *3.2808399)/100) & "+00"
else
  lblStation = int((segLen *3.2808399)/100) & "+" &  right(int(segLen *3.2808399),2)
end if
  FindLabel = lblStation
End Function
XanderBakker
Esri Esteemed Contributor
Hi William Delmar ,
I was able to connect to the data and I see what you mean. The field reference I proposed has a fixed reference to the length of the line. There is a special reference that points to the measurement: $measure.
Your code would look like this:
var segLen = Round($measure * 3.2808399, 0);
return Round((segLen - (segLen % 100)) / 100, 0) + Text(segLen % 100, "+00");
Resulting in:
XanderBakker
Hi WDelmar ,
I think you should be able to do something like this:
var segLen = Round(LengthGeodetic($feature, 'feet'), 0);
WilliamDelmar
Mr. Bakker,
Thank you. I will give it a try.
WilliamDelmar
When I tried the expression, I received an error of:
Invalid expression.
Error on line 1.
Projection is invalid
I altered line 1 to read:
var segLen = Round(Length($feature, 'feet'), 0);
And it returned a result of:
Expression is valid.
When I ran the expression, my labels read all the same number. Is there a way to have the resulting number change based on the distance from the beginning of the line?
Thanks.
XanderBakker
Hi William Delmar ,
Can you explain what projection your data has? You mention that all your labels read the same number. What is that number? Your original VB script used esri__measure. Is that value (attribute) available in the data in the web map? I guess you have points and want to show the measurement based on that value, right? And the value is in meters and you need to translate that to feet?
WilliamDelmar
They were drawn in the Projected Coordinate System: NAD 1983 UTM Zone 15N, Projection: Transverse Mercator, WKID: 26915; with Geographic Coordinate System: GCS North American 1983, WKID: 4269.
The number on the labels is 1076+61. This appears to be the total length of the line when converted into feet and further converted into a method of stationing that is used for roadways and levees.
The esri__measure is the Shape Length of the lines drawn. The data is located in the map, though not currently a web map.
I am using existing data that is centerlines for levees. We collected observations that use the measurement along this line as a reference for points and lines along the centerline.
XanderBakker
Hi William Delmar ,
Is it possible to share a sample of your data? Or create a group in ArcGIS Online and invite me to that group (using [email protected]_utility_esri_co) and share the sample of the data in that group? It is so much easier if I can see and interact with the data.
XanderBakker
Hi WDelmar ,
Before you share your data, could you try this:
var segLen = Round($feature["Shape__Length"] * 3.2808399, 0);
WilliamDelmar
Here is a link to the group that was created. https://arcg.is/GPKiX
Hopefully, it works.
XanderBakker
Hi WDelmar ,
It seems that you shared layer package, but I think I can open it in ArcGIS Pro and publish it in my portal for the moment to understand the data you have. It seems the data source is still pointing to your SQL Server database and I don't have access to that.
Is the data stored in the Enterprise Geodatabase and you are creating a web map consuming the service?
