Concatenation of Fields
920
05-08-2023 09:37 PM
Bradmayger
I need to concatenate 8 or 9 fields, using "/" between the text, and no spaces if it is blank, the following code had worked, but has since failed.
def update(a, b, c, d, e, f, g, h):
strArray = []
if a != ' ':
strArray.append(a + "/")
if b != ' ':
strArray.append(b + "/")
if c != ' ':
strArray.append(c + "/")
if d != ' ':
strArray.append(d + "/")
if e != ' ':
strArray.append(e + "/")
if f != ' ':
strArray.append(f + "/")
if g != ' ':
strArray.append(g + "/")
if h != ' ':
strArray.append(h + "/")
str = "".join(strArray)
str = str.strip()
str = str.lstrip("/")
str = str.rstrip("/")
return str
BFS_concat = update(!GDE_01B!, !GDE_02B!, !GDE_03B!, !GDE_04C!, !GDE_05B!, !GDE_07B!, !GDE_08B!, !GDE_09B!)
Any ideas please ?
Cheers
Brad
DanPatterson
MVP Esteemed Contributor
Error message would be useful.
Are there  any nulls in the fields? and are they all text?
('a', 'b', 'c', 'd', 'e', '', 'g', 'h')
flds = [a, b, c, d, e, f, g, h]
    """concatenate flds"""
    out = ""
    for i in flds:
        if i:
            out += i + "/"
    if out[-1] == "/":
        return out[:-1]
    return out.strip()
'a/b/c/d/e/g/h'
  If so, the above example would seem simpler
... sort of retired...
