Automatically Create Records in related Tables from Point Feature Class
16828
21
03-12-2015 11:34 AM
PaulMcBride
Hello Everyone,
I have a point feature with a single field used as the the attribute key for relationship classes to other tables.  I am looking to automatically create a row into the related tables with the key field populated from the point creation.  Any ideas how to auto populate the tables with that key?
Below is a screenshot of the inside of database.
Thank you!
Paul McBride
ThomasTri
Seems like this is the classic example for creating a Relationship Class Extension. By developing ArcObjects code, and hooking into the relatedObjectCreated method, you should be able to add a record to the related table.
PaulMcBride
Thomas,
I have no experience with ArcObjects.  Is this something I could do farely easily or with guidance?
Paul
ThomasTri
I don't think the code would be all that difficult, but learning ArcObjects is not an afternoon project :-).
PaulMcBride
Okay sounds good.  I will look into that if i can't get my Python to work.
JoshuaChisholm
Hello Paul,
I'm working on a python solution (I don't know ArcObjects either). Can you let me know the exact name of the key field for the complaint point file?
Thank you!
PaulMcBride
Hey Josh,
The name of the field is "ComplaintNo".
Thank you again!
Allison_Hockey
Hello Thomas,
I am also trying to achieve this same workflow, some years later! Is there some literature or a webpage out there that describes how to accomplish this workflow?
JoshuaChisholm
Hello Paul,
I have prepared a Python Add-In that should do what you need. I attached a .zip of it. Note that:
  • To install the Add-In, run "PythonAddIn.esriaddin"
  • You can see the raw code under the "Install" folder
  • If you make any changes, run the "makeaddin.py" and then re-install with "PythonAddIn.esriaddin"
If you haven't already, you can download the python add-in wizard here. You can use "addin_assistant.exe" to change the Add-In documentation.
Let me know if it works out for you!
Also, I ran into one limitation. If the user has an attribute table open (from one of the related tables), they will have to close and re-open the table to see the changes. More info here.
PaulMcBride
Hey Josh,
I'm sorry but I do not see the attached ZIP.  Thank you again for your hard work!
JoshuaChisholm
That's odd. It's working for me. Try this link.
