ArcGIS Data Pipelines- Error Message When Output Layer Editor Tracking is Enabled
1124
11-26-2025 11:36 AM
Amanda__Huber
MVP Regular Contributor
Hi Data Pipelines team,
I recently came across a strange error when working on setting up a new Pipeline.
When enabling Editor Tracking on my output layer, the Pipeline throws this error:
Message code: ADP_102139
If I turn off editor tracking, the data previews with no issues/errors.
I was unable to find anything about this in the documentation. Is this a bug or by design?
Amanda Huber
DuncanMackey
Hi @Amanda__Huber,
Correct, a layer with editor tracking enabled can't be appended to when specifying a uniquely identifying field. It looks like we missed that limitation in our documentation. I'll make a note to add it.
Sorry for the confusion, and thank you for reporting this!
Duncan
Amanda__Huber
Hi @DuncanMackey ,
Thanks for your response. Can you explain why Pipelines can't use editor tracking with unique ID field?
In addition for our project needs for this, I see a lot of value in this for others.
Amanda Huber
JonathanMcD
@DuncanMackey @Amanda__Huber
Being able to this would be super useful. I can understand, from a "data integrity" point of view why it may not exist, however, updating status records or creating updates from a calculated matrix into an inspection etc would be massively beneficial.
DuncanMackey
@Amanda__Huber @JonathanMcD
Understood, thank you both for the feedback. It's currently a limitation with the append operation that we use for writing to feature layers, but I've taken note of your requests and we will look for a solution! I agree that it would be a very useful addition.
Thanks both,
Duncan
