To link Microsoft Access Table
4593
10-15-2014 06:41 AM
htoonchao
Hi all,
I would like to join the information from .accdb file which included several tables.
There is always other way around it which you can export out .dbf table and join with unique identifier.
I want to have direct access from that table which I want to make it dynamic.
.accdb file is the database that individual staff will be inputting information everyday.
Back in the day using using 9.0 has no problem but now the newer version doesn't allow me the access .accdb table.
Thanks in advance.
JakeSkinner
Esri Esteemed Contributor
Hi Katrin,
You will need to open ArcCatalog by going to Start > Programs > ArcGIS.  You will then be able to add the 'Add OLE DB Connection' there.
JakeSkinner
Hi Htoon,
Take a look at the following web help link:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
KatrinKarrer
I have the same problem. I also read the ArcGIS Help, but I cannot find the command "Add OLE DB Connection" or the "ArcCatalog" (except via the menu bar) respectively. The Catalog only shows "Add Database Connection"..
Could anybody tell me more about this?
Thanks in advance.
Katrin
JakeSkinner
Hi Katrin,
htoonchao
Thanks Jake.
