Snapping causes ArcMap to crash
2212
12
05-11-2017 01:37 AM
TheoFaull
ArcMap 10.4
When drawing a new shape or re-drawing an existing shape using the trace tool, ArcMap will sometimes crash if snapping is enabled.
These are the options I have enabled:
Perhaps when moving my cursor around the map as I trace, it puts my PC resources under too much load. It's like the amount of nodes/verticies available to snap to is TOO DAMN HIGH! So ArcMap just gives up and dies.
So far it's only crashed when drawing/re-shaping polygons.
If I trace with snapping turned off, it doesn't crash.
Has anyone else experienced this?
I'll send a crash report next time it happens (but does anyone look at those anyway?)
(side question: when writing a question on this forum, you are required to publish it in a location. however, there are no suitable locations for ArcMap related queries. Any ideas why this is?)
JayantaPoddar
Close all ArcGIS Desktop applications. Try Resetting your ArcGIS application profile
Think Location
DanPatterson_Retired
This type of query would go to https://community.esri.com/community/gis/managing-data?sr=search&searchId=4826934c-b9de-4d34-a8c4-74...‌ since it deals with feature construction, creation, manipulation and related issues
PS... trace mode for most applications and geometry is overkill.  How much spatial resolution do you really need?  I have seen people using trace on simple curves or even straight line segments which is courting disaster.
TheoFaull
I need trace so that a new polygon drawn will sit perfectly adjacent to an existing polygon. I can't have any gaps.
I wonder if reducing the snapping tolerance may help... as that would minimise the number of nodes/verticies the cursor is recognising as potential snapping points.
shan_sarkar
For gaps you can use database topology and keep them in check. i.e. assuming you are working with feature classes and not shapeiles
Please refer
Geodatabase topology rules and topology error fixes—Help | ArcGIS for Desktop
Creating a topology—Help | ArcGIS for Desktop
~Shan
MichaelVolz
Where does your source data reside (SDE database, file geodatabase, other)?
If SDE, what type of database are you using (Oracle, SQL Server, other)?
you should be using the append polygon tool (I think that is what it is called) to ensure that there are no slivers/gaps in existing polygons
by Anonymous User
Not applicable
Yes we do, so keep sending them in with as much additional information as you can.
If you have a reasonably reproducible case also contact support and supply the data if possible so we can fix it for all users.
shan_sarkar
Does the issue replicate when using a fresh blank arcmap. Have someone else log on to your machine with their profile and see if it still crashes, or you can log on to another machine and test the same.
This way you can rule out a few things and the issue becomes more clearer and easier to troubleshoot.
~Shan
