import replica xml file error
981
01-24-2023 01:45 PM
demin_hu
I am using ArcGIS pro 2.9.
I could export and import a dataset with XML workspace document.
I could create a replica as XML file successfully, but I couldn't import replica XML file to a file or an enterprise geodatabase, and got the following error.
Any help will be appreciated.
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
demin_hu
Did some more tests, it could  successfully import  replica xml file which created with ' Replica Access Type  : Simple', but not ' Replica Access Type : Full'.
