broken data source crashed ArcMAP
7324
14
02-27-2017 07:39 AM
JohnWatermolen
When I have broken data source on in the TOC, when I click on it ArcMAP crashes. I find it very frustrating and have several other users that experience the same thing
DanPatterson_Retired
hah love it... don't blame the retired... isolate the file, you may have files with bad geometry or totally corrupt.  As I said, remove the good stuff leaving the bad stuff... then when that is done, you can run a Repair Geometry on the remainder to see if there are any problems.  You can run a check geometry, but there is no point if it just tells you that you have problems and need to repair it anyways.
Lake_Worth_BeachAdmin
If you know where the file is located just remove the broken layer and add it again new.
can you right click properties and set it from there? Don't click that checkbox that seems to cause issues with users.
RebeccaStrauch__GISP
Although I've only had mixed results in the past, you can try the mxd utilities
Using the MXD Doctor utility—Help | ArcGIS Desktop
And Using the Document Defragmenter utility—Help | ArcGIS Desktop
JoshuaBixby
MVP Esteemed Contributor
Mixed results?  That would be a kind way of describing my experience with trying to repair broken MXDs.  The Document Defragmenter works when the MXD is intact, but it hasn't solved many problems for me.  By the time I resort to using these tools, I feel like I have better odds playing Scratch & Win.
I agree, but if all else fails, it never hurts to try it (on a copy).  Once in a while it helps....but I still never win scratch-offs.
Btw, I mentioned them mainly because most don't even know they exist anymore....for the reason you mentioned.
