best practice when connecting to SQL DB
1711
07-09-2024 07:21 AM
Labels (3)
clt_cabq
I am able to connect to a SQL Server database (not a GDB) as either an OLE DB connection or as an SDE connection (using the New Database Connection option in Catalog)  - is there an advantage to using one over the other? My use case is mainly extracting a table (approx 250K records) via a python script before applying various manipulations, merging with other data and loading into a GDB.
George_Thompson
Esri Notable Contributor
I would connect as the .SDE connection if using Python in Pro. I think this would provide you the easiest user experience.
I am not sure what the difference is between the 2 are, but usually only make .sde connections to non-geodatabases in SQL Server.
Just know that there are some limits to what can be done via ArcGIS client and .sde connections to non-geodatabases: https://pro.arcgis.com/en/pro-app/latest/help/data/databases/databases-and-arcgis.htm
--- George T.
George_Thompson
--- George T.
clt_cabq
@George_Thompson thanks for the response, this is what I suspected would be the answer. I did find one bit of functionality available as an SDE connection versus the OLE DB method - Summarize fields doesn't seem to be enabled in the OLE DB connection but it is in the SDE, so that makes a big difference when exploring data for me.
George_Thompson
That makes sense. I would think that the .sde connection would work with most GP tool available. The OLE DB connection would have limited functionality with tools.
--- George T.
