Address Points "bunched" for many roads
1124
06-07-2013 11:44 AM
DemianCarpenter
I'm trying to map recycle and garbage bins for our municipality. After geo-coding based off of the addresses, many of the address points are bunched on one side of the street. Some are put in front of the correct parcels for an entire street. I've attached a picture and pdf of a small section of the map created. [ATTACH=CONFIG]25135[/ATTACH]
JoeBorgione
When geocoding against a line, the process simply interpolates the location (x,y) of the given address based on the range of addresses for a given street and the length of the street.
As a very simple example, suppose you have a street called Main St and the 100 block is address ranged 101-199 on the odd side and 100-198 on the even side.  This section of Main ST is 300 meters long.  The address of 150 Main ST should fall on the even side of the street, at just about the middle of the block (approximately 150 meters from the intersections).  Could be that the house is actually on the odd side of the street and at the far end of the block.
This can lead into a discussion of accuracy and precision; locating 150 Main St at the half way point is accurate; if you use GPS'd address points, they would much more precise as you would have occupied the driveway at 150 Main ST and recorded the actual x,y.
You have to decide how precise your data needs to be and the associated costs with that level of precision....
by Anonymous User
Not applicable
Original User: Carpendr
Yeah, that's what I figured. I've been trying to make my own Address Locater, but have only messed with it a bit. Costs? I'm trying to keep that outta my workplans. I'll keep trying options out until I deem it futile, which will most likely be soon. I only need it to help the solid waste managers figure out routes based on cart count, and I'm going to try to persuade them to use the data anyway. Not like the presentation matters at this point.
JoeBorgione
Now that you have the demand points mapped sufficiently, take the next step and use network analysis to work the vehicle routing...
by Anonymous User
Not applicable
That's the plan. Going to try it with the bus routes first. Less streets. I don't even know if I have the license for it. Going to find out.
