Error: 8004205a: Cannot process remotely built mosaic dataset items
4916
06-11-2013 12:51 AM
MatthiasHoehner
Hello
With ArcCatalog 10.1 SP2 I connect to on a ArcSDE 10.1 SP2 for Oracle Database as User "X".
I created the dataset "X.Mosaik3".
I give full access privileges to "X.Mosaik3" for all user/roles.
I try to add raster data (raster type CADRG/ECRG) to the mosaic dataset "X.Mosaik3" an than I got following errors:
Preparing distribution of mosaic dataset operation across 2 parallel instances
Error: 80070057:
Error: 80070057: Cannot acquire a write lock on the specified dataset [Mosaik3]
Error: 80070057: Invalid function arguments
Error: 8004150b: Network I/O error [SDE.GDB_Items]
Error: 8004205e: 64 mosaic dataset items could not be built
Is there a problem with the two parallel instances?
PS: The Import of the same raster data in a File Geodatabase was successfull.
Thanks for your help!
Regards Matthias
VinceAngelo
Esri Esteemed Contributor
What version of ArcGIS are you really using?  (SP2 for 10.1 was never released)
Opening a Tech Support incident is probably your best route to resolving this.
- V
MatthiasHoehner
Sorry, we use 10.1 SP1.
I will open a Tech Support incident.
Regards Matthias
