Pictures don't show in published story map (map tour)
3880
04-30-2016 05:37 PM
Nicole_Ueberschär
When putting my Story map together I had the references to the pictures and the thumbnails already correctly stored in my feature class that I uploaded to AGOL. Unfortunately for the big pictures the URLs were missing and were only saying something with "undefined?token=...." So I added the URLs manually for every single picture (which was annoying enough). All big pictures were showing after that process. After editing, saving and sharing the Story Map I opened it with the provided link and had to find my big pictures missing again. Opening it in edit mode was driving me almost mad now because I found the same link as before with "undefined?token=....."
Can please someone advise what I did wrong with my picture URL?
I have the pictures on my own website e.g. http://www.nicole-in-ruanda.de/wp-content/uploads/2016/04/20160423-120235_Dubai_Eingang_Internet_Cit... for the big picture and http://www.nicole-in-ruanda.de/wp-content/uploads/2016/04/20160423-120235_Dubai_Eingang_Internet_Cit... for the corresponding thumbnail. Both links are stored in my feature class but only the thumbnails showed up.
Just found this question Paths to pictures are not being saved. Paths to pictures keep being set to undefined after saving. as very similar to my problem. Somehow unfortunately I have in contrast to this posting a field called pict_url, and in the popup I defined in my map, the pictures show. At least I'm glad that the links are still there...
MarkCooney
Occasional Contributor III
Nicole,
See here for a list of valid field names: GitHub - Esri/map-tour-storytelling-template-js: The Story Map Tour is ideal when you want to presen...
It looks like you are using a field called pict_url.  Try changing it to pic_url, which is included as a valid field name.
-Mark
Nicole_Ueberschär
For those who want to have a look at the issue:
The map where the pictures show in the popup: http://arcg.is/24v9rYv
And the app where only the thumbnails show:  http://esri-rw.maps.arcgis.com/apps/MapTour/index.html?appid=b40b5d01e15948d5800262c2aaab8740
MarkCooney
Nicole,
-Mark
Nicole_Ueberschär
Thank you Mark! That helped! I thought I took the same headers as in the sample csv file but obviously I didn't.
