Hi there,
Trying to include a mailto link in the storymap I'm working on--I've figured out how to do this, opening up an email client new message window, but every time it also opens a new blank tab in my web browser. I'm using Chrome. Seems to have something to do with the "Target=blank" in code, but I don't know what to replace that line with so that it keeps the user within the storymap.
Thanks for your help!
The issue described above with mailto links in Map Journal is a known issue that is not likely to be fixed.
Mailto links are now supported in the new ArcGIS StoryMaps. See https://community.esri.com/message/884208-mailto-links
What does your link look like? Is it something like this:
<a href="mailto:someone@example.com?Subject=subject here&Body=body text">
Link display text
</a>
I suppose it also depends if a client has an email application installed.
Here's the source code: <a href="mailto:treeteam@irvingtonpdx.com" target="_blank">. This works for opening up a mail client, however it also opens up a blank tab in my web browser. When I erase the target="_blank" it doesn't change anything, in fact it reappears.
So it probably needs a value in the target property. Does using "_self", "_parent" or "_top" change anything? Maybe it will be overwritten automatically, but it is worth a shot.
I just tested and all have the same behavior, a new blank page will be opened.
Nope, none of them work, and it gets overwritten each time. Adding a "mailto" button to the Edit Section window would be a great improvement in the next update.
Would be good to create an idea for it: ArcGIS Ideas
Just to be sure, I will tag Rupert Essinger and OEvans-esristaff who know a lot more than me about StoryMaps.
