Mailto links in Journal story map
2043
7
10-31-2017 02:09 PM
RamseyJeff
New Contributor III
Hi there,
Trying to include a mailto link in the storymap I'm working on--I've figured out how to do this, opening up an email client new message window, but every time it also opens a new blank tab in my web browser. I'm using Chrome. Seems to have something to do with the "Target=blank" in code, but I don't know what to replace that line with so that it keeps the user within the storymap.
Thanks for your help!
Tags (1)
OwenGeo
Esri Notable Contributor
The issue described above with mailto links in Map Journal is a known issue that is not likely to be fixed.
Mailto links are now supported in the new ArcGIS StoryMaps. See https://community.esri.com/message/884208-mailto-links
Owen Evans
XanderBakker
Esri Esteemed Contributor
What does your link look like? Is  it something like this:
<a href="mailto:someone@example.com?Subject=subject here&Body=body text">
    Link display text
</a>
I suppose it also depends if a client has an email application installed.
RamseyJeff
New Contributor III
Here's the source code: <a href="mailto:treeteam@irvingtonpdx.com" target="_blank">. This works for opening up a mail client, however it also opens up a blank tab in my web browser. When I erase the target="_blank" it doesn't change anything, in fact it reappears.
XanderBakker
So it probably needs a value in the target property. Does using "_self", "_parent" or "_top" change anything? Maybe it will be overwritten automatically, but it is worth a shot.
XanderBakker
I just tested and all have the same behavior, a new blank page will be opened.
RamseyJeff
New Contributor III
Nope, none of them work, and it gets overwritten each time. Adding a "mailto" button to the Edit Section window would be a great improvement in the next update.
XanderBakker
Would be good to create an idea for it: ArcGIS Ideas
Just to be sure, I will tag Rupert Essinger  and OEvans-esristaff who know a lot more than me about StoryMaps.
OwenGeo
Owen Evans
