Enterprise Cascade Story map and Youtube videos
1155
06-26-2019 01:34 PM
JoeBorgione
A couple of years ago this post raises the question of an Enterprise (Portal) Cascade Storymap not being able to add a YouTube video.
Owen Evans‌ responded with:  'We are looking at supporting this in 10.6.1 (or possibly a 10.6 patch). When this is implemented an administrator will need to add your own YouTube API key to a configuration file in the Cascade app on your portal.'
I'm still getting the same problem today and we are at ArcGIS Enterprise 10.6.1: has this been implemented yet and if so, where is the documentation describing the procedure?
That should just about do it....
OwenGeo
Esri Notable Contributor
Hello Joe -- This has not been implemented in ArcGIS Enterprise. The current workflow to utilize videos in a Cascade story map is to host the video file on your own server or use Vimeo. You can also consider using a Journal or Series story map instead since those support YouTube directly.
Owen Evans
JoeBorgione
Okeydokey.  Thanks for the quick response Owen!
JoeBorgione
There seems to be another undocumented feature:  When I try to add an <iframe> specifying the height and width to an Immersive page, the <iframe> text gets scrambled once I hit the check mark.  However, it works if I just link to it as an image.  Sigh....
before check:
<iframe width="560" height="315" src="https://www.####.###/gisapps/images/ArcGISDescribe.mp4" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
after check:
<iframe src="https://www.####.###/gisapps/images/ArcGISDescribe.mp4" height="315"></iframe>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
CaitlanDowling
Will this ever be implemented? Or is this something that just won't happen ever as the focus shifts to the new storymaps roll out?
I am trying to use one of ESRI's own videos, is it available on Vimeo?
https://www.youtube.com/watch?v=LHDCRjAxpI0
ThomasGreen3
We still hope for the best!
