Issue with calcite-components-angular 2.0.0
5201
17
12-06-2023 07:06 AM
ForrestLin
Failed to compile with calcite-components-angular 2.0.0.
No problem to compile with calcite-components-angular 1.11.0.
ShaneBuscher
This didn't work until I deleted node_modules and package-lock.json. Now I'm good to go.
ForrestLin
I did:
1. Add "allowSyntheticDefaultImports": true to the tsconfig.json, and run 'npm i --save-dev @types/sortablejs'.
2.
<calcite-shell content-behind>
      <app-esri-map></app-esri-map>
</calcite-shell>
MarkW
by Esri Contributor
Sorry for the late response. Glad you were able to get it working!
Mark W
ForrestLin
Hello Mark,
Thank you for your help. Is it possible not content-behind?
I'll go to Palm Springs for Esri DevSummit next week and would like to talk to you.
Regards,
Forrest
MarkW
by Esri Contributor
Hello Forrest,
Unfortunately I will not be attending the Dev Summit, but many of my colleagues and developers for calcite will be there who will be happy to discuss with you.
I found another Community post regarding content-behind and possible workarounds.
https://community.esri.com/t5/calcite-design-system-questions/calcite-shell-needs-content-behind-to-...
Hopefully this is helpful.
Mark
Mark W
ForrestLin
Hello Mark,
We want layout like this:
There are some issues, which I'd like to discuss with your colleagues and developers for calcite there.
1. Sub menu <calcite-menu-item slot="submenu-item"> doesn't work.
2. Action group <calcite-action-group> doesn't work.
3. Scroll bar of table doesn't work.
4. Pagination <calcite-pagination> can't place on the right (end)
5. Shell panel <calcite-shell-panel slot="footer" position="bottom" layout="horizontal" resizable> can't be resized.
6. If I set slot to "panel-bottom": <calcite-shell-panel slot="panel-bottom" position="bottom" layout="horizontal" resizable>, the bottom is above map:
ForrestLin
It is OK if the display mode is float. But it's not on the bottom.
<calcite-shell-panel slot="panel-bottom" position="bottom" layout="horizontal" display-mode="float" >
ForrestLin
This issue is resolved by adding:
<calcite-shell-panel slot="panel-top" />
