Issue with calcite-components-angular 2.0.0
5184
17
12-06-2023 07:06 AM
ForrestLin
Failed to compile with calcite-components-angular 2.0.0.
No problem to compile with calcite-components-angular 1.11.0.
KittyHurley
Hi @ForrestLin, wasn't able to reproduce the installation with the calcite-components-examples angular example. If you could create an isolated example to share where we could reproduce, you could file a bug issue for the team to investigate and prioritize for a future release.
ForrestLin
Is it possible for you to create a Esri case and for me to share screen with you?
KittyHurley
To file a support case, please visit Esri technical support.
ForrestLin
I'll go to Esri technical support to file a support case.
Thanks.
ShaneBuscher1
I am having the same problem with esri/calcite-components-angular 2.4.0 and Angular 16. By chance did you resolve?
ForrestLin
No lucky for me.😂
MarkW
by Esri Contributor
Hello Shane,
I was able to resolve this issue by adding "allowSyntheticDefaultImports": true to the tsconfig.json file for the app, and running 'npm i --save-dev @types/sortablejs'.
Hopefully this works for you.
Mark W
ForrestLin
Hello Mark,
I have resolved this issue by adding "allowSyntheticDefaultImports": true to the tsconfig.json, and running 'npm i --save-dev @types/sortablejs'. But I'm not able to show the map.
Could you please provide an example with map?
This example doesn't have map:
https://github.com/Esri/calcite-components-examples/tree/main/angular
Thanks.
ForrestLin
 I have fixed the issue of not showing map. The calcite-shell needs to set to be content-behind.
<calcite-shell content-behind>
      <app-esri-map></app-esri-map>
</calcite-shell>
