Failed to compile with calcite-components-angular 2.0.0.
No problem to compile with calcite-components-angular 1.11.0.
Hi @ForrestLin, wasn't able to reproduce the installation with the calcite-components-examples angular example. If you could create an isolated example to share where we could reproduce, you could file a bug issue for the team to investigate and prioritize for a future release.
Is it possible for you to create a Esri case and for me to share screen with you?
To file a support case, please visit Esri technical support.
I'll go to Esri technical support to file a support case.
Thanks.
I am having the same problem with esri/calcite-components-angular 2.4.0 and Angular 16. By chance did you resolve?
Hello Shane,
I was able to resolve this issue by adding "allowSyntheticDefaultImports": true to the tsconfig.json file for the app, and running 'npm i --save-dev @types/sortablejs'.
Hopefully this works for you.
Hello Mark,
I have resolved this issue by adding "allowSyntheticDefaultImports": true to the tsconfig.json, and running 'npm i --save-dev @types/sortablejs'. But I'm not able to show the map.
Could you please provide an example with map?
This example doesn't have map:
https://github.com/Esri/calcite-components-examples/tree/main/angular
Thanks.
