Calcite Design System Questions
104
1.4M
245
| IDEA | In this example there are two comboboxes where the second depends on selection of the first one. In the first/left co... by SebastianKrings Frequent Contributor 0 5 | 0 | 5 | 186 | |
| IDEA | When using the selection-display=”fit” and selecting all but one values, the combobox correctly shows some values and... by SebastianKrings Frequent Contributor 0 5 | 0 | 5 | 135 | |
| IDEA | In a combobox one can type text which leads to the suggestion list to be filtered to only show values matching the ty... by SebastianKrings Frequent Contributor 0 4 | 0 | 4 | 133 | |
| IDEA | When using not using selection-display (defaults to ”all”) a new row is added to the combox when there is not enough ... by SebastianKrings Frequent Contributor 0 2 | 0 | 2 | 107 | |
| IDEA | Usually using “fit” mode there are chips of the selected values fitting the space. When space runs out the “fit” opti... by SebastianKrings Frequent Contributor 0 2 | 0 | 2 | 116 | |
| POST | How to use Calcite Tailwind Preset?https://www.npmjs.com/package/@esri/calcite-tailwind-preset?activeTab=readmeThanks... by ForrestLin Frequent Contributor 0 2 | 0 | 2 | 112 | |
| POST | 0 | 3 | 167 | ||
| POST | My goal is to reposition some calcite popovers when viewed on a small screen size like mobile view using CSS/JavaScri... by JasonBartling1 Regular Contributor 0 4 | 0 | 4 | 266 | |
| POST | I'm working with the calcite components and narrowed my issue to this. When I use:<script src="https://js.arcgis.com... by DeanWilson Regular Contributor 0 3 | 0 | 3 | 230 | |
| POST | I am using a Calcite label with a Calcite checkbox and when combined in a div with a button they do not vertically al... by EricErtl Frequent Contributor 0 5 | 0 | 5 | 332 | |
| IDEA | The Calcite dropdown component has a close-on-select-disabled property that allows the dropdown to stay open even aft... by jdyerLACSD Occasional Contributor 0 1 | 0 | 1 | 150 | |
| POST | I'm using the radio-button-group and I'm getting a 404 error logged to the console for the following url https://js.a... by ForrestCain Occasional Contributor 0 2 | 0 | 2 | 215 | |
| POST | I want to use a combobox where the combobox items don’t display any selection indicators—no checkboxes or radio butto... by LefterisKoumis Frequent Contributor 0 2 | 0 | 2 | 302 | |
| POST | The new labels for inputs is excellent. However, this seems to remove the spacing between inputs, particularly the ma... by DavidJantz Occasional Contributor 0 1 | 0 | 1 | 242 | |
| POST | Not sure if there's a current enhancement open for this, but adding the option to set the clearable action to true/fa... by AudreyWatson Emerging Contributor 0 0 | 0 | 0 | 150 |
In the Calcite Design System place, members can find information on the design system, ask questions, and participate in discussions.
| User | Count |
| 9 | |
| 2 | |
| 2 | |
| 1 | |
| 1 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
