How to use autocomplete of calcite-input-text?
1435
10-18-2023 11:44 AM
ForrestLin
How to use autocomplete of calcite-input-text? Please provide an example.
KittyHurley
Calcite leverages autocomplete, which provides autofill from the user-agent, and may require the following of the component:
  1. The component is provided with a "name" and/or "id" attribute,
  2. The component is housed within a form, and/or
  3. The form also contains a submit button
ForrestLin
Any example? Sample code?
Thanks
KittyHurley
@ForrestLin you can refer to the MDN example in the above thread for the specifics. Below are examples with Calcite and native elements, depending on the user agent:
<!-- Native  example -->
<!-- <label for="firstName">First Name:</label>
<input name="firstName" id="firstName" type="text" autocomplete="given-name" /> -->
<!-- Calcite example -->
<calcite-label for="firstName">First Name:</calcite-label>
<calcite-input name="firstName" id="firstName" autocomplete="given-name"></calcite-input>
ForrestLin
Hello Kitty,
Thank you!
Is it possible to auto-complete input data from backend: web api/service, database?
