Expression to update parent record when related table is updated
3217
7
02-05-2024 09:29 AM
MikhaylaB
I have a parent layer called hydrants with a field named "Class" and a related table called Inspections with the relevant field named "GPM". The "Class" field accepts values 'Blue-1500', 'Green-1000-1499', 'Orange-500-999', and 'Red-0-499', and the "GPM" field in the related table accepts integers 0-1500.
I need help producing an arcade expression to update "Class" based on the "GPM" value when a new record is added to the related table via an attribute rule.
2 Solutions
MikeMillerGIS
Esri Frequent Contributor
MikhaylaB
I was unable to use GlobalID to GUID for this, not sure what the hang-up was. If anyone comes across this and has a similar issue, I created a relationship class based on ObjectID to an integer field manually populated with that ID, hydrant ID's in my situation. The relationship forward path was set to my parent class. The rule's field is the integer field. The code is as follows:
var parent_id = $feature.hydrantOBJID ;
var parent_class = FeatureSetByName($datastore, "Fire.SDE.Hydrants", ["OBJECTID", 'class'], false);
var parent_records = Filter(parent_class, "OBJECTID = @parent_id");
var updates = [];
var i = 0;
var new_value = 'no gpm';
if ($feature.GPM >= 1500) {
new_value = "Blue - 1500 GPM or Greater";
else if ($feature.GPM >= 1000) {
new_value = "Green - 1000-1499 GPM";
else if ($feature.GPM >= 500){
new_value = "Orange - 500-999 GPM";
else {
new_value = "Red - 0-499 GPM";
for (var row in parent_records) {
// If the parent row is null or has a different value, updated it
if (IsEmpty(row['class']) || row['class'] != new_value)
updates[i++] = {
'OBJECTID': parent_id,
'attributes': {"class": new_value}
return {
'result': parent_id,
'edit': [
{'className': 'Fire.SDE.Hydrants',
'updates': updates
MikeMillerGIS
MikhaylaB
That looks similar to the expression I've been cobbling together, do you think this looks almost correct? I'm not good enough with arcade to tell where I'm fumbling.
MikeMillerGIS
Line 1: You FeatureSetByName should have a list of fields passed as the third param
Line 4:  relatedInspections.map,  I do not know what that dies.  That is a FeatureSet.  You should call first or loop over the featureset and get a list of all the GPM Values.  Then you can call Max on it
Your return statement, just return the value.  If you set the rule on a field, it will map it to the field
MikhaylaB
I have tried to implement the referenced script, and I don't receive any errors but it doesn't update the parent table. I'm not sure if I've made a mistake in the code or if it is my data setup. I have tried the relation ship class with GlobalID to GlobalID, Global to GUID, and the original ObjectID to hydrantOBJID.
Parent Table:
Related Table:
Code:
var parent_id = $feature.parentglobalid ;
parent_id = Upper(parent_id);
var parent_class = FeatureSetByName($datastore, "hydrantCopy", ["GlobalID", 'class'], false);
var parent_records = Filter(parent_class, "GlobalID = @parent_id");
var updates = [];
var i = 0;
var new_value = '';
else {
updates[i++] = {
'GlobalID': parent_id,
return {
'edit': [
{'className': 'hydrantCopy',
'updates': updates
MikeMillerGIS
The code is using parentglobalid, but in your screen shots that is blank.  You need to adjust the code and the sql statement in the Filter(FeatureSet...) to match how your data is set up.
MikhaylaB
Do you have any insight into how I could combine the below code into one attribute rule? I need GPM to be calculated by a value entered into the Flow field on the same table and update the parent class accordingly.
//Calculate GPM
var flow = $feature["Flow"];
var gpm = 0;
if (!isEmpty(flow)) {
gpm = (29.7 * (2.5 * 2.5) * Sqrt(flow) * 0.9)
return gpm;
//Update Parent Class
var parent_id = $feature.hydrantObjid ;
var parent_class = FeatureSetByName($datastore, "hydrantCopy", ["OBJECTID", 'class'], false);
var updates = [];
var i = 0;
else {
updates[i++] = {
return {
'edit': [
'updates': updates
MikhaylaB
var updates = [];
var i = 0;
else {
updates[i++] = {
return {
'edit': [
'updates': updates
