concatenation of fields
1010
04-07-2020 10:05 PM
Bradmayger
I am attempting to concatenate fields in a feature class.
The item to be calculated is T_GDE_con
and has 18 possible single entries, plus the concatenated entries, from 18 fields.
Any insight please ?
update([GDE_01C], [GDE_01D], [GDE_02C], [GDE_02D], [GDE_03C], [GDE_03D], [GDE_04D], [GDE_04E], [GDE_04F], [GDE_04G], [GDE_05C], [GDE_05D], [GDE_07C], [GDE_07D], [GDE_08C], [GDE_08D], [GDE_09C], [GDE_09D])
PRE LOGIC script code
def update(a, b, c, d, e, f, g, h, i, j, k, l, m, n, o, p, q, r):
    strArray = [ ]
    if a != ' ':
        strArray.append(a + "/")
    if b != ' ':
        strArray.append(b + "/")
    if c != ' ':
        strArray.append(c + "/")
    if d != ' ':
        strArray.append(d + "/")
    if e != ' ':
        strArray.append(e + "/")
    if f != ' ':
        strArray.append(f + "/")
    if g != ' ':
        strArray.append(g + "/")
    if h != ' ':
        strArray.append(h + "/")
    if i != ' ':
        strArray.append(i + "/")
    if j != ' ':
        strArray.append(j + "/")
    if k != ' ':
        strArray.append(k + "/")
    if l != ' ':
        strArray.append(l + "/")
    if m != ' ':
        strArray.append(m + "/")
    if n != ' ':
        strArray.append(n + "/")
    if o != ' ':
        strArray.append(o + "/")
    if p != ' ':
        strArray.append(p + "/")
    if q != ' ':
        strArray.append(q + "/")
    if r != ' ':
        strArray.append(r + "/")
    str = "".join(strArray)
    str = str.strip()
    str = str.lstrip("/")
    str = str.rstrip("/")
    return str
DanPatterson_Retired
Can we assume it didn't work? or do you have an error or a sample output?
You don't appear to be using the python parser for the field calculator
The script will probably fail if any of the inputs are not text/string and null values in the fields will cause issues as well.
Beyond that, the expression could be simplified if you can answer the questions on the first line
JoeBorgione
I don't see what you are trying to accomplish, but besides that you might want to replace all those if statements with elif.  Also, str as a variable is problematic;  using a function name spells trouble for me.
