Workforce not connecting to a survey in Survey123
1089
11-01-2021 01:02 PM
GISManager4
I created a new workforce project. Survey123 integration is enabled.
I have ID and Location fields mapped out.
But when I try and use the Survey at Assignment, Survey123 opens but the linked survey does not open. Surveys created using Connect.
I tested on another, existing Workforce project an got the same behavior.
CraigGillgrass
hello @GISManager4 what happens when you open Survey123?  Does it prompt you to sign in?  Does it display your list of surveys?
Craig
GISManager4
It takes me to the Home page on Survey123 app. If I open the survey that is linked to Workforce, the data in the fields do not come over Workforce (ID & Location.)
CraigGillgrass
Hello @GISManager4
This sounds like an issue with Survey123 honoring the url link and opening the correct survey, looking to @ZacharySutherby or @JamesTedrick to weigh in on this.
Craig
