I created a new workforce project. Survey123 integration is enabled.
I have ID and Location fields mapped out.
But when I try and use the Survey at Assignment, Survey123 opens but the linked survey does not open. Surveys created using Connect.
I tested on another, existing Workforce project an got the same behavior.
hello @GISManager4 what happens when you open Survey123? Does it prompt you to sign in? Does it display your list of surveys?
Craig
It takes me to the Home page on Survey123 app. If I open the survey that is linked to Workforce, the data in the fields do not come over Workforce (ID & Location.)
Hello @GISManager4
This sounds like an issue with Survey123 honoring the url link and opening the correct survey, looking to @ZacharySutherby or @JamesTedrick to weigh in on this.
Craig
