Link Existing version to newly created job in WFM(Web)
470
05-17-2022 09:48 AM
naveenbesri
We are configuring WFM(web) for a process where a version will be created from a batch job. we need to link the existing version to the our process(while opening ArcGIS Pro through "open pro project items", we need to set the batch job created version name). Kindly let me know the workable solution in this scenario.
Note: we are using ArcGIS Enterprise 10.9.1
JFarmer
Hi @naveenbesri
Unfortunately, this is not currently possible with Workflow Manager. You will need to use the version created in Workflow Manager via the Create Version step to open in ArcGIS Pro via the Open Pro Project Items step.
Can you explain a little more about your batch job process and what the larger workflow is? That will help us get a better idea of the use cases in this area as we potentially look at this for a future release.
Thanks!
Jonathan
