Is there a spec for WM Server API?
1337
12-13-2022 11:27 PM
ViktorSafar
I would like to generate a C# client for the REST API that is described here: https://developers.arcgis.com/workflow-manager/api-reference/rest/
At the bottom of that page, it implies that OpenAPI Generator was used to produce the docs - but I cannot find a way to get the OpenAPI spec that I could feed into OpenAPI Generator to generate a client.
JFarmer
Hi @ViktorSafar
You can get the Open API doc from your Workflow Manager Server machine here:
That should be what you need as input to the OpenAPI Generator.
Jonathan
JFarmer
Hi @ViktorSafar
Jonathan
