WM REST API jobSearch returns "currentStep" as an array but claims a string type
524
12-15-2022 11:56 AM
ViktorSafar
Post a job search request and specify to return "currentStep" in fields
https://{{env.hostname}}/workflowmanager/workflow/{{env.workflowitemid}}/jobs/search?token={{env.token}}
    "num": 10,
    "start": 0,
    "q": "1=1",
    "fields": ["JobId", "JobName", "priority", "dueDate", "currentStep"]
Response specifies that "currentStep" is a string but its value is actually an array.
    "q": "1=1",
    "fields": [
            "name": "JobId",
            "fieldType": "String"
            "name": "JobName",
            "name": "priority",
            "name": "dueDate",
            "fieldType": "DateTime"
            "name": "currentStep",
    "results": [
            "gM5_BuxmS6yKneDz4hNGew",
            "JOB_1",
            "Low",
            "2022-12-23T10:30:57Z",
                "tempName"
            "avDKQmdgSGSlxC79hZju_A",
            "JOB_2",
            "Low",
            "2022-12-23T10:31:01Z",
                "tempName"
    "start": 0,
    "nextStart": -1,
    "num": 2
I attempted to modify the request to include "currentSteps" (plural) which is an actual property of a `job` but the API errored with "field does not exist".
