I get error "Failed to publish service definition", when I attempt to publish my Workflow Manager service.
5385
05-10-2016 10:33 AM
MarkSamuels
I'm using version: ArcGIS Workflow Manager 10.2.1 and when I attempt to publish my workflow manager service via the ArcGIS Workflow Manager Administrator it fails. Can anyone assist here?
Please see the error message below in red that has been returned.
Executing: UploadServiceDefinition C:\ProgramData\ESRI\WMX\10.2\Database\MyWorkflowManagerService.sd "C:\Users\Mark.Samuels\AppData\Roaming\ESRI\Desktop10.2\ArcCatalog\arcgis on MS-TR-PC_6080 (publisher).ags" # # FROM_SERVICE_DEFINITION # STARTED USE_DEFINITION NO_SHARE_ONLINE PRIVATE NO_SHARE_ORGANIZATION #
Start Time: Tue May 10 12:27:35 2016
Submitted.
Executing...
Executing (Publish Service Definition): PublishServiceDefinition i54d43e17-e6dd-422c-9823-d9cff5034fa2 # {"buildInitialCache":false} #
Start Time: Tue May 10 12:27:36 2016
Validating publish options.
Connecting to the server.
Getting basic item metadata for service definition upload.
Getting server information (server folders, data stores, etc.).
Extracting manifiest from uploaded service definition.
Validating service definition.
Determining service's input folder name.
Attempt to find service's input folder.
Creating the service.
ERROR 001369: Failed to create the service.
Failed to execute (Publish Service Definition).
Failed at Tue May 10 12:27:36 2016 (Elapsed Time: 0.39 seconds)
Failed.
ERROR: the server's publishing job didn't succeed.
Failed to execute (UploadServiceDefinition).
Failed at Tue May 10 12:27:37 2016 (Elapsed Time: 1.40 seconds)
JenniferMcCall4
Does the user running the ArcGIS Server service have access to the JTX_ tables?
MarkSamuels
Hi Jennifer,
Thanks for the prompt response!
Yes, the respective user has the following database role membership permissions "db_datareader" and "db_datawriter" to the sde geodatabase. The JTX_ tables are within this geodatabase.
