Export Workflow to a pdf
2329
01-31-2023 05:03 AM
VassilisTrigkas1974
We would like to export the structure of a workflow in a pdf, and we don't know how to do this. I can only imagine a print screen and stitching the images. Any better ideas?
MaryMozingo
Hello Vassilis. For Workflow Manager (Classic), open the Workflow Manager Administrator application, then open your workflow and you will see a Print tool at the top of the workflow editor. Then you can Print to PDF or a printer.
bbaker_tngeo
Your interface looks different than what I see. Are you using the Workflow Manager Server or Workflow Manager (classic)? If using the service-based Workflow Manager Server, you can select the Print tool at the top of the diagram editor and then Print to PDF (or some other variation of that, depending on your browser).
VassilisTrigkas1974
We use Workflow Manager (classic).
MaryMozingo
VassilisTrigkas1974
Correct @MaryMozingo, I keep your answer as Accept as Solution. I found it too, but I'm not an administrator so I couldn't find it before.
Thank you for your answer.
