Changing an order of Extended Property groups
1660
06-18-2013 11:13 AM
AndyOldham
Does anyone know how to change the order of extended properties (not the field order but the entire property group of the extended table)?
In WMX Administrator, I go to the Job type that has extended property, and there are two Extended property tables defined: 1)JTXX_EXTPROPS 2) CustomTable1.
In WMX under the Extended Properties tab, the CustomTable group is at the top and the JTXX_ExtProps ins at the bottom.
Is there a way to change this to switch the order of the table..?
Thanks.
