Change job type to a closed job in JTX 3
1529
08-01-2012 06:05 AM
Ulises
We are looking forward to migrate to Workflow Manager 10, but until then, we have several closed jobs that were created with an incorrect job type.  We want to delete this job type but we can't since it has these related jobs in the database.  Is there a way to change or update the job type for the closed jobs so the job type in question can be drop from the database using the JTX Admnistrator.
Ulises Feliciano Troche
NishiMishra
You would need to edit the job type related to these jobs in the JTX Jobs table and put any other job type which is part of JTX. You can edit the table inside ArcMap. Once you change the job type, the jobs will be associated with the new job type and you can delete the other job type which was incorrect.
