Web AppBuilder on my own server won't connect
3065
01-20-2017 09:52 AM
ElizabethMiller
I have followed all instructions regarding setting up the proxy.config and config.json -- I think I have done what others have done: I've followed all tips I've found at What's the proper configuration for proxy.config and config.json for a self-hosted Web AppBuilder fo... and Internal ONLY Web Map Sharing Issues.  I've created a Web Map, downloaded the code, deployed it on my own server, registered the app with arcgisonline using my own url, and authenticated it so I have a client id and client secret. I have the client id and client secret in the proxy config. I have the app id in the config.json. When I launch the website I get the blue loading screen and then the screen goes white. Here are the errors I get in Chrome developer tools. Can someone tell anything about what might be the problem?
Thank you for any tips!
Failed to load resource: the server responded with a status of 404 (Not Found)
http://<myUrl>/<mySite>/jimu.js/css/fonts/avenir-next/3a42a252-67ff-4186-88cf-762f56719ca1.woff Failed to load resource: the server responded with a status of 404 (Not Found)
http://<myUrl>/proxy/proxy.ashx?http://<myorg>.maps.arcgis.…6961&callback=dojo.io.script.jsonp_dojoIoScript1._jsonpCallback&wab_dv=2.3 Failed to load resource: the server responded with a status of 404 (Not Found)
main.js?wab_dv=2.3:272 Error
at Object.f.error (init.js:981)
at init.js:87
at c (init.js:103)
at d (init.js:103)
at b.Deferred.reject.errback (init.js:105)
at c (init.js:104)
at d (init.js:103)
at c (init.js:104)
at d (init.js:103)
(anonymous) @ main.js?wab_dv=2.3:272
main.js?wab_dv=2.3:12 Error
at init.js:87
at c (init.js:103)
at d (init.js:103)
at c (init.js:104)
at d (init.js:103)
at c (init.js:104)
at d (init.js:103)
(anonymous) @ main.js?wab_dv=2.3:12
ElizabethMiller
RobertScheitlin__GISP
Closing thread as it is a duplicate of this active thread:
https://community.esri.com/thread/189048-web-appbuilder-on-my-server-gives-white-screen
