Missing Widget Gap in Web AppBuilder solution
4422
6
01-20-2021 05:49 PM
ShelleySchott
I though I would share a solution to an issue which we were facing where a custom widget would leave a gap when it was redeployed.
Problem:
When a custom widget update/ redeployed which has previously been added to the Web AppBuilder gets corrupted, the custom widget ‘disappears’ from the Web App and the location of this widget also disappears. There is a gap and changing the widgets around does not fix this gap, it persists.
Setup:
  • ArcGIS Enterprise 10.7.1
  • WAB: Not Developer edition
  • Custom Widgets added as Portal Items
  • Foldable theme
  • Supposed to have 5 widgets below the search widget
Cause:
Orphaned Portal IDs which don’t exist in Portal in the Json file of the Web App.
Solution:
1. Open ArcGIS Online Assistant: https://ago-assistant.esri.com/#
2. View the JSON in AGO
3. Open the offending Web App:
4. The foldable theme has 5 widget placeholders:
Position 1 – Left: 55, Right: 45, Relation to: Map
Position 2 – Left: 105, Right: 45, Relation to: Map
Position 3 – Left: 115, Right: 45, Relation to: Map
Position 4 – Left: 155, Right: 45, Relation to: Map
Position 5 – Left: 205, Right: 45, Relation to: Map
Search for the position of the missing widget – In this case it’s position 3
5. Check the Portal ID it’s referencing exists
In our case, the Portal ID didn't exist
6. Search for the Portal ID for the redeployed widget that does exist
7. Replace the Portal ID in the Web App JSON (The existing Portal ID) in ArcGIS Online Assistant and save the changes.
8. The widget is now back and can be re-added if needed
6 Comments
by Anonymous User
Not applicable
Thank you for sharing
by Anonymous User
Not applicable
Really useful! Thank you!
With those widget placeholders, can you create new widget locations in JSON with new positions? To theoretically extend out the number of widget locations?
Thanks
ShelleySchott
@Anonymous User , yes theoretically you can add a new widget location.
In the json there is a position location for the widgets in relation to the map, so you can add a new widget location. You would need to follow the spacing sequence when adding the new widget. Below is an example of what the json looks like.
by Anonymous User
Not applicable
The search widget disappeared from Web App builder - Launchpad Theme. Normally, the search widget was located on the header. I can see it in the controller tab however, WAB doesn't allow me to configure the search widget. I removed the feature layer from the map that was connected to the search widget. Could that be the reason why it's missing? I intended to connect it to a new layer however, I have no control over the search widget now. Any thoughts?
MehdiPira1
@ShelleySchott ,
Great! Thanks.
GeorginaScholes
Hi @Anonymous User
Did you ever figure out what the problem was or find a solution? I have a similar issue.
Thanks.
