Identify Widg 3.0  Shows Link URL in popup, Not ID results link icon
1362
08-16-2012 11:22 AM
MattBorden
Using:
Identify Widget 3.0
Internet Explorer 9
Windows 7
FlexViewer 3.0
Apache/Tomcat
Problem:
After migrating from Identify Widget 2.4 to 3.0,
the Link Icon won't appear next to the Identify window field results, the popup URL link does appear (see attached word doc graphic)
Things I've tried:
  • tested in Chrome and Firefox browsers: problem persists in those browsers as well
  • Cleared the REST services CACHE
  • tried using <fields all="false" >  AND <fields all="true" >
For complete code: see attached txt files
Sample Code:
    <layers onlythese="true">
      <layer>
        <name>Parcel</name>
          <field name="PARCEL"  />
          <field name="parcel_id" alias="ID" />
          <field name="prop_locat" alias="Address" />
          <field name="parcel_acr" alias="Acreage" />
          <field name="own_name" alias="Owner" />
          <field name="own_addr" alias="Owner Address" />
        </fields>
        <links>
<link includeinresults="false" field="PARCEL" alias="More Parcel Info Click Here" tooltip="More Parcel Info Click Here" >
                <linkprefix> http://gis.slco.org/ServLookup/index.htm?lu=PDS&parcel=  </linkprefix>
                <linksuffix></linksuffix>
                <iconfield></iconfield>
    <iconprefix></iconprefix>
    <iconsuffix></iconsuffix>
</link>
        </links>
<zoomscale>15000</zoomscale>
            <forcescale>true</forcescale>
      </layer>
  </layers>
RobertScheitlin__GISP
Matt,
   Hmm... What happens if you manually specify a icon in the link?
    <layer>         <name>Parcel</name>         <fields all="false" >           <field name="PARCEL"  />           <field name="parcel_id" alias="ID" />           <field name="prop_locat" alias="Address" />           <field name="parcel_acr" alias="Acreage" />               <field name="own_name" alias="Owner" />           <field name="own_addr" alias="Owner Address" />          </fields>             <links>         <link includeinresults="false" field="PARCEL" alias="More Parcel Info Click Here" tooltip="More Parcel Info Click Here" >         <linkprefix> http://gis.slco.org/ServLookup/index.htm?lu=PDS&parcel= </linkprefix>                             <linksuffix></linksuffix>             <iconfield></iconfield>         <iconprefix></iconprefix>         <iconsuffix>assets/images/i_lego.png</iconsuffix>         </link>     </links>     <zoomscale>15000</zoomscale>     <forcescale>true</forcescale>     </layer>
Matt,
   Your issue is that you are telling it not to include that in the results.
Should be:
<link includeinresults="true"
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
by Anonymous User
Not applicable
Original User: mb1471
Thanks for the feedback
I did switch the include link tag to true as follows
The link field itself now appears in the ID field results window,
but the link icon which the user clicks to open the web resource
is still not displaying (see attached graphic)
Any thoughts, Thanks Matt
Matt,
by Anonymous User
Not applicable
that fixed it, it's working
Thanks Matt
Matt,
   The need to specify the link icon will be fixed in the next version.
