Popup in Geoprocessing Widget
2313
08-20-2012 12:42 PM
EricStarn2
Hello All,
I have a geoprocessing widget that I have been testing and it appears to work fine.
Now I would like it to, when it shows the results open up a popup to display some info about it.
According to the ArcGIS Viewer for Flex resource page, it says that you can do this however I can not seem to get it to work.
Here is the code I used for the Output Parameter that I want to open
<param name="Selected_Basin"
               geometrytype="polygon"
               label="Basin"
               required="true"
               type="featurerecordset"
               visible="true">
          <popups>
           <Fields>
            <Field name="Name"
              visible="true">
            </Field>
           </Fields>
          </popups>
            <renderer type="simple">
                <defaultsymbol alpha="0.5"
                               color="0x00FF00"
                               type="simplefill">
                    <outline width="1" color="0x00FF00"/>
                </defaultsymbol>
            </renderer>
        </param>
What am I doing wrong?
Any info would be great
Thanks Eric
EricStarn2
OK
I am still struggling with this.
Basically, I am trying to have a pop-up window display on the output for the ran geoprocess.
I thought that according to the resource page that you were to put the pop-up tags in the output parameter.
But I appear to be wrong.
The output is a simple polygon with one filed name to display named {Name}
Any help or direction would be appreciated.
Eric
EricStarn2
OK,
I got my popup to work but I would like it to open with the result output not just when you click on it.
do use the preload option for this or something else?
