Use AssignTerminalConnections command to UtilityNetwork from Python Script
1707
01-17-2023 05:00 AM
geopamplona
I'm trying to assign terminals against a UN but I can't seem to pass configuration correctly to command from a python script.
https://solutions.arcgis.com/utilities/help/utility-network-automation/tool-reference/modify-termina...
I am using
arcpy.pt.AssignTerminalConnections(
r"c:\un.gdb\un\Network",
"Sewer",
True,
True,
None)
Command return ERROR 000732: Asset Package: the dataset c:\un.gdb\un\Network does not exist or is not compatible.
or other error that not found AP_Networks domains
How should I correctly use this command to run against a UN network?
Does the network have any requirements?
Thanks !
MikeMillerGIS
Esri Frequent Contributor
Thank you for reporting it.  We found a bug with calling the function from python.  We will get this fixed in the next release of untools, which should be this week.  Are you on 2.9?
MikeMillerGIS
geopamplona
Yes, i am using ArcGIS PRO 2.9.5
Thanks !
MikeMillerGIS
We were actually able to push the update to conda just a few minutes ago.  If you update, all should be fixed!
