Two UN version 5 but I need version 6
3138
8
03-07-2023 08:39 AM
gpgisandsky
I have two UN:
UN A) a hydroelectric UN version 5 with a hydroelettric Domain+Structure
UN B) an electric UN version 5 with a electric Domain+Structure
I'm using ArcGIS Pro 3.1+untools v3.1, ArcGIS Server/Portal v11, Postgres 13.
These UN are in different DB (enterprise and fgdb too and I have asset package gdb too).
Now I would like add the electric Domain (UN B) to hydroelectric UN (UNB) so I can manage all data using a unique database.
When I use apply asset package using untools 3.1 on ArcGIS Pro 3.1 I got the following error:
- The Utility Network must be version 6
How I can update my UN v5 to version 6? Why untools ask to upgrade?
Thank you
Giuseppe P.
MikeMillerGIS
Esri Frequent Contributor
The untools can only work with the version of the utility network that ArcGIS Pro creates(which is a v6 with 3.1).  You can upgrade your utility networks to v6 - https://pro.arcgis.com/en/pro-app/latest/help/data/utility-network/utility-network-dataset-administr...
MikeMillerGIS
gpgisandsky
It works fine. Thank you.
JohnGoat
hi @MikeMillerGIS
I get this error when I try to run the Upgrade Dataset tool. my current utility network version 6
What needs to be done to upgrade to version 7?
MikeMillerGIS
Whats the full path you entered?
JohnGoat
i am working for file geodatabase
D:\work\UN\ArcGIS_Pro_3_3\UtilityNetwork.gdb\Electric
MikeMillerGIS
That is the FeatureDataset, not the Utility Network.
JohnGoat
Since the tool name is dataset upgrade, I showed the dataset 😞
Thank you
MikeMillerGIS
Technically, all classes are datasets.  Glad it is working now
