Table not show domain description in experience builder utility network
931
02-18-2024 11:51 PM
NadiaAlami
Hi everyone,
we encounter problem when we run the tracing, the result of the selected features in the table only show the domain code not the description.
but in default table it show the domain description.
What should we do. Thank you.
gis_KIWI4
MVP Regular Contributor
@NadiaAlami - Increasing the Coded Domains value on the service page should fix it. We have it set at a 1000000.
If that doesn't work then there was solution to increase the javaheapsize.
https://community.esri.com/t5/arcgis-utility-network-questions/domain-names-not-displaying-via-in-fe...
Hope that helps 🙂
