Question about Service Territory
915
08-07-2024 06:17 AM
TSmith
Hello-
I have a water UN (Enterprise 11.1, Version 6) and a need to change the Service Territory FC. I assume the workflow for this would be to export the UN to an asset package, modify the service territory FC, then run the asset package to geodatabase tool?
My concerns with this are: The DB is a production DB that is used quite a bit. (SQL Server 2019). Would I have to create a new DB on SQL Server to house the new UN? Or could I just overwrite the existing feature dataset. Any guidance in this area is appreciated. Thanks!
RobertKrisher
You will need to create a new database.
RobertKrisher
