Intended Sewer UN Editing Workflows
1100
05-24-2024 07:29 AM
TSmith
Hi Everyone.
Out of curiosity- what is the intended editing workflow for updating a manhole location in the base model for wastewater UN?
I get the below image when updating a manhole (structure) location in the Naperville sample data, which seems to stack the pipe connections on top of each other. Is this the intended behavior?
This was a question I encountered as a result of updating manhole locations from GPS sources, but shouldn't the pipe connections remain on the pipes they were connected to initially? Just curious. Thanks!
MikeMillerGIS
Esri Frequent Contributor
What version of ArcGIS Pro?  I recall some issues with moving and features collapsing.  I am in 3.3 and when I move the Structure Junction, the pipe connections move correctly
to
MikeMillerGIS
to
TSmith
3.1.4, unfortunately my organization is holding off on upgrading to 3.3 across the board, it will likely happen at some point but I can test on 3.3 and see if I have the same issue. Thanks!
