Good afternoon,
What is the way you recommend to rename a Domain in an Utility Network. The domain is a regular domain imported from a GN, not a UN domain related to assettypes.
Let say that the domain name is called DmMunicipality, and we want to rename it UNDmMunicipality.
Thanks
@SanchezNuñez - I haven't had any issues renaming domains using the Domain View.
I haven't found any issues with this in the past.
If you wanted to play it safe - you could always - create a new domain and assign it to relevant fields.
You can use the Domain to Table tool to extract the domain and then Table to Domain Tool to add the add the domain.
@JoseSanchez - No they weren't.
The original question is specific to non-UN attributes.
