How to enforce Attribute Rule in Composite Template
1138
08-20-2024 11:05 AM
SusanONeill1
I created a Constraint Attribute Rule so that a Sewer Tap (SewerJunction) cannot be placed without snapping it to a Mainline (SewerLine).  It works fine if I just place a Tap.  I also created a Group Template to generate a Tap at the end of a Sewer Lateral.  That works as well.  But I cannot get it to enforce the snapping rule when using the Group Template. So if I draw a Lateral and it creates a tap at the end of the line, it doesn't show an error if the line isn't snapped to the mainline.  I tried creating another Attribute Rule to enforce the Lateral snapping to the Line without referencing the Tap, but that didn't work either.  I tried it with just drawing a Lateral (not using the Group Template) and with drawing the Lateral / Tap Group Template, but neither worked.  I've played around with creating a validation Attribute Rule using Arcade to see if the "Intersects" results are null , but without success (I have almost no experience with Arcade).  Is there an easier way to enforce snapping in the ArcPro and / or Utility Network environment?   Thanks for your assistance.
RobertKrisher
If you want the rule to be that a tap can only exist between a lateral and a main, try adding edge-junction-edge rules that enforce that then REMOVE all the junction-edge rules for the tap.
RobertKrisher
SusanONeill1
That worked!  Thank you.  Looks like I will need to do the same for some other rules.
